[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 678: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4700: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4702: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4703: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4704: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
Arkansas Riders Forum • View topic - Tire Pressure?
Page 1 of 1
Tire Pressure?
PostPosted: Tue Dec 13, 2011 9:24 am
by bake621
I have a ZX6R and just put Bridgestone Battle Axe B018 i am looking to find what people are running for tire pressures during winter and sumer? THANKS
Re: Tire Pressure?
PostPosted: Tue Dec 13, 2011 7:21 pm
by smileyman
For Highway miles? Commuting? Race track? Canyon racing?
The best bet is start with your manufacturer specs, going lower for more traction and higher for more mileage...your results of course will vary. Give us some more specifics and i am certain you will get a wide response...
Re: Tire Pressure?
PostPosted: Wed Dec 14, 2011 2:53 pm
by bake621
it will be a lot of hwy to from work with twisties on the weekends its a 2000 ZX6R with stock suspension.
Tire Pressure?
PostPosted: Wed Dec 14, 2011 3:56 pm
by GSXRyan
My guess... 34-37 weekdays, 28-32 weekends.
I had the bt0s once and didn't like them when they got some miles on them. I ran around the weekday pressure in them since I was going back and forth to school a lot. But I recommend checking on what Bridgestone recommends.
Re: Tire Pressure?
PostPosted: Thu Dec 15, 2011 9:50 am
by smileyman
Ditto. My street / commuting pressures are 36-39, sporty highway miles depending on temps 30-32...
Re: Tire Pressure?
PostPosted: Thu Dec 15, 2011 11:46 am
by bake621
thanks for the input
Re: Tire Pressure?
PostPosted: Thu Dec 15, 2011 11:54 am
by Ironx
Hey Brandon, I believe your tires are BT016s, it might make a difference on pressure due to the type of compound, welcome to Arkriders :ok .
Re: Tire Pressure?
PostPosted: Sat Apr 12, 2014 8:16 pm
by Sqrly2U
I use Dunlop Q2s and run 30-31 daily. My weight is 145 without gear. If I am on the track using Dunlop D211s, I run 23-24 rear and 28-29 front. I have zero issues running my tire pressures providing sag is properly set. Scott
